Old Jul 16, 2008 | 05:49 PM
  #60 (permalink)
SRT6nTulsa's Avatar
SRT6nTulsa
Default Re: Not a Poser just had to share
Originally Posted by kldiet
I just got a nice set of AMG 75mm center caps from dongparts off ebay for my SRT-6. These (the ones with the green tree, cam and AFFALTERBACH AMG logo) do not fit perfectly and will require some re-engineering to fit tightly. Has anyone else had this problem? I don't want to spin one off at 80mph. The catch clip on these is about .5" offset from the 75mm rim so when inserted, there is alot of in and out play. I found another ebay vendor that sells a 70mmID-73mmOD rubber centering ring that looks like it might work like a big rubber band to secure the cap from the inside. This vendor (aaiautomotiveaccessories) also sells the 17mm lug bolt caps (various colors). Will let you know how this goes. Has anyone else tried these caps on a Crossfire SRT-6 wheel?
Karl
If they are anything like the silver "star" caps I had, it's an easy fix. There is a metal ring that applies pressure to the plastic clips. Take it off, stretch it out larger, and put it back on. Your center caps should stay snug.
