I don't have photoshop, but a cheaper downgraded program. I was thinking about some magnetic number signs for the side to use at events such as Tail of the Dragon, etc... I figured 16" diameter would be about right. Your thoughts on the size? 04 for the year of the car. Will the magnetic sign cause any harm to the paint if only used occasionally?
Also I thought about a 'mustang' type stripe on the rocker panel in silver to match the trim. About 2" wide with 1/4" stripes on each side of it. That would be permament. The stripe would rap around the rear and cut short to the air difusser. The front would taper off parallel to the lower grille. Just some ideas for now.
