Old Jul 19, 2008 | 08:56 PM
70GT6's Avatar
70GT6
Default Re: stuff on my new 2005 coupe
Originally Posted by cought in crossfire
Yes let the dealer see what they may do about this problem with the paint it may fall under corrosion, there may be somthing they may help you with.
Nope - corrosion is limited to rust through. (and then it is restricted to from the inside to out, rust-through)
This does not sound like a paint flaw it is clearly something on the paint and can it be proven the spots where there when purchased?
Dealer may try to clean it up but odds are you can do FAR better yourself.
I would at least try some of the above, on at least a small spot, to see if you can clean it off. (IMO)
