Old Jul 22, 2008 | 05:48 PM
RPM's Avatar
RPM
Moderator
Default Re: How much should Eibach springs cost to install?
Originally Posted by FP
So far the quotes I got are for 4 hours, and about $450 - $550. I think that's a bit steep.
4 hours may be about right. The labor seems high IMO.
Also, a spring compressor is not required if you use the method that BrianBrave used. I put the Eibachs in, took them back out, and put the stocks back in, all without a spring compressor.
