Old Jul 23, 2008 | 01:40 PM
Isellthem's Avatar
Isellthem
Default Re: How much should Eibach springs cost to install?
FP,
Search BrianBraves thread Lowered my Ride for $24.95 . . . it convinced me to do it myself. All you need are jack stands, a floor jack, and the tools mentioned . . . no spring compressor needed. Take your time, and don't worry about man handling the front a little. The torx you may need is a 55 if I remember correctly. I also recommend a good size screw driver to use as a pry bar. Brian doesn't mention it, but I took out the front shock completely to give myself a little more wiggle room. Give yourself an afternoon start to finish . . . tops.
