Re: For those who've changed their shift ****..
Hi Mike
Be a little careful with the boot being semi frozen to the ****. Use a hair dryer on the (lowest) setting. Hold it a couple of inches away from the top of the boot & work it around the entire boot slowly. It should become supple enough to gently pry it off the **** without to much force. If not apply a 2nd or 3rd round of heat, again not overdoing too much in one spot & stop & check if any progress is made. Good luck.
Crossfireone
