Re: Engine Cover / Air Cleaner Removal Questions
If you're talking about the gray cover right on top then it's easy & no air tubes need to be removed. Just grab the front & pull up.......do the same for the sides & voila', you're good to go!
Put it one the same way you removed it......line it up with the clips & just give a good push.
