Old Jul 28, 2008 | 08:04 PM
Valk
Default Re: Engine Cover / Air Cleaner Removal Questions
The engine cover lifts free from four grommets (2 in the back and 2 in the front)
The air tubes can be pulled away from the cover and flexed to be removed first or simply lift the corners of the cover one at a time and once it is free from the engine it will pull free from the tubes anyway.
If you are planning to change the 2 air filters turn the cover over to expose the bottom side.
You will see two rectangular covers with a torx screw in each corner.
You need to remove the 4 torx screws from each cover to expose filters. Then replace filters and replace the rectangular covers and screws and align the engine cover with the oil filler cap and opening in cover for it and press down firmly on all four corners of the cover.
Be sure the rear of the cover is aligned correctly over the air intake (throttle body)
