Old Aug 1, 2008 | 09:42 AM
cruzinquick's Avatar
cruzinquick
Default Re: At the track after the LET tune
Originally Posted by MikeR
The track is at about 200 feet elevation. Things should get very interesting in 4 or 5 weeks when the temps get back to the 60's and 70's.
MikeR
I take it your running at woodburn dragstrip (197' elevation)? Looks like a great track with lots of action. What was the temp when you actually ran? The high yesterday was 80 and low 50, at least that's what accuweather.com says. I would have to guess your humidity at best was 50%. I would have to guess your going to be at a 12.34 with a little cooler weather and less humidity. A low 12 will have to be with 15% or less humidity, temp can go as high as 68 degrees. You have great elevation but your humidity changes the DA. If your barometric pressure was 30.10 and the rest is accurate your DA corrected elevation for that day was 1611 feet. It's only going to get better. Nice going way to get out there. If you want that time to drop quicker, throw out that intake and get a needswings.
