Old Aug 1, 2008 | 11:17 AM
maxcichon's Avatar
maxcichon
Default Re: Splash Shield Delete
Originally Posted by Stogey
Max, I would set your thermo-couple just behind the intake at the manifold.
Just my Dos Centavos
I was thinking there or under/beween the OEM airbox and the center of the intake manifold, maybe spaced so it doesn't touch anything.
Which brings up another question: has anyone tried to insulate/shield the bottom of the OEM airbox from the intake manifold? There is a goodly amount of clearance between the two with damned little airflow. Either a reflective plate or fiberglass cloth could be installed? Just trying to block infrared pickup.
Even if it resulted in 5-10 degree reduction it should help?
Whatcha' think?
