Old Aug 1, 2008 | 05:23 PM
waldig's Avatar
waldig
Default Re: Splash Shield Delete
I do not know how you would get the temp reading from the ECU. The temps at the throttle body are important as it is an indicator of how the intake air sensor readings will be. The passage thru the supercharger even at idle add to this inlet air temp and if it get too high, the ECU will pull timing / boost and therefore power.
I just know that this reading will give a general feel for the temp benefits of any alterations, such as my current grill modification post in the SRT section. Enjoy
Woody
