Old Aug 2, 2008 | 10:28 AM
maxcichon's Avatar
maxcichon
Default Re: Need help removing headlight bulb
FP!
Yes, when you remove the rubber cap, look inside and you'll see a spring wire clip that must be pushed to the side and then swung out of the way to release the bulb. It's very easy once you see what to do. Be careful and don't push it too far or it'll come off and is a real bear to get out of the bottom of the housing.
P.S.
I'm workin' on it!
