Originally Posted by racermp
those red and black wires, are they on the ballast of the hid kit? if so, thats the negative and positive. you wanna take out the low beam buld (outer light) the connector that 2 wires on it, u can use those to connect to the 2 wires on the hid kit.
since it's aftermarket, if those hid ballast wires don't fit the stock plug, u can create a plug wires (break off the stock bulbs conectors and plug solder them onto the hid balast ones so u can plug in the ballast to the stock connector, or figre something out.
So I took the low beams out and I see that there are two black wires connecting to the low beam? This is wear I'm lost? I'm not sure where to connect the red and black.
