Re: TPMS and BAS/ESP light on
Plus.......you have way to much air in the tires if you are using the OEM/stock fitment. The pressure should be 32psi front and 33psi in the rear, TPMS will trigger when there is a 25% difference in psi this includes over inflation also.
