Old Aug 3, 2008 | 02:27 PM
70GT6's Avatar
70GT6
Default Re: Remove splash shield = dirt/grime = heat?
Can not see there being a big benefit - unless you are racing and can open the hood to let the heat out - then I can see where having the bottom of the compartment open would help. But if you are driviing under normal situations all air movement is front to back and the belly pan is open at the rear.
Keep it clean and more important dry.
