Originally Posted by sowardcustoms
do you have a limited or a base model? the wire for the hand brake is just so the system knows you are at a stop so you can watch the dvd player i just put the wire to ground and flipped the switch on the bottom of the unit the switch is a little micro switch under some foil tape. if you do that you can watch movies going down the road.....hope this helps
I have the limited. Thanks for the tip.
