Thread: 50K service
Old Aug 4, 2008 | 04:57 AM
maxcichon's Avatar
maxcichon
Default Re: 50K service
From page 247 of the owners' manual:
Your Flexible Service System (FSS) — see Understanding
Your Instrument Panel section — should give you an
exact indication of when your vehicle should be scheduled
for service and which schedule to follow.
Additional Periodic Maintenance
items should also be
performed beyond the items listed in the following charts
to assure the optimum performance of your Crossfire.
SCOPE OF WORK FOR “A” SCHEDULE
MAINTENANCE SERVICE
Oil Change
Change oil and replace filter
Maintenance
Lubricate hood hinges, latch, and secondary latch
Reset FSS Display
Function Check
Horn, hazard warning flashers, turn signals, and indicator
lamps
Headlamps and exterior lighting
Windshield wipers and washer system
Inspection
Check front and rear brake pads for lining thickness
Check tires for damage and general condition
Check tire inflation pressures and correct if necessary
Fluid Levels
Check fluid levels for the following systems and correct if
necessary. Should there be a loss of fluid that cannot be
explained by regular use, trace and eliminate the cause.
Engine cooling system (check corrosion inhibitor/
antifreeze)
Hydraulic brake system
Power steering system
Windshield washer system
250 MAINTENANCE SCHEDULES
MAINTENANCE
SCHEDULES
