Re: Help with stock intake removal?
The two intake tubes will just slide out also. The Y tube clips on with two black plastic clips, top and bottom. Just pull them out and pull the Y tube back towards the firewall. I believe that you can actuall take the air boxes and Y tube off as a unit if you want. Just dont twist the air boxes out of the Y tube when you pull them up off thier rubber mounts.
MikeR
