Old Aug 6, 2004 | 10:52 AM
Dan Root's Avatar
Dan Root
Banned
Default
Over all performance if you do maintain close to the same overall ht. And put good performance tires won't be that much different! BUT your ride roadfeel will change alot smoother feel less bumpy but not soft. The real key factor is using a performance tire again.You might loose 5-10% handling from just a tire & wheel change, you should try M.B. wheels.
