Old Aug 5, 2008 | 02:53 PM
nox1s's Avatar
nox1s
Default Re: Scosche VW01B (No Blue Wire?)
Originally Posted by Arnotm1
Thank you for the quick reply, I will surely try this and once I receive the removal tools will attempt the installation. Did you need to bypass the factory amp, if so how did you do this, what were the connections you needed to either connect or disconnect?
Thanks!
Don't listen to Crutchfield on anything they say, except you DO need to switch the yellow & red wire.
You don't need to bypass the amp, re-wire any speakers, etc. Just match up the colors on the harness to your headunit, make sure to connect the pink wire to the blue amp turn on wire, and you should be set..
