Old Aug 5, 2008 | 05:57 PM
Valk
Default Re: Cold Air Intakes?
Originally Posted by copycat
This single intake setup functions better then the standard two, or is it that theres more space on that side of the radiator to accommodate the pipe, so that it can be mounted in front of the radiator eliminating hot engine air. Also, with this setup can you still utilize the engine cover.
The single intake provides a good source of fresh air.
I believe there is equal space on either side of the radiator once the stock intake port is removed.
It also connects directly to the engine and the plastic throttle OEM throttle body is removed.
This is also a restrictive area on the stock intake.
The na engine cover as far as I know has not been able to be modified to be used along with this intake.
The install is easy and if you ever want to switch it back to stock it is even easier.
