Old Aug 6, 2004 | 09:56 PM
landho's Avatar
landho
Default
Originally Posted by Dan Root
MB is same check offset ...
the bolt pattern is same as MB, 5x112. The offsets ARE NOT the same. Xfire rear offset is 22mm on 9" wide rim. MB does not use these offsets in the rear... Diff offsets along with wheel width changes will change the track of your vehicle. Which may change the handling of your vehicle...just be aware of these issues.
