Old Aug 10, 2008 | 08:21 PM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: Coolant change info?
Originally Posted by ohnoesaz
Hey guys... I've read the specs for the coolant, buts its confusing compared to most cars. Is there an aftermarket off-the-shelf brand that meets the specs that you guys already know of?
And... For draining, just drain the radiator, which will include the block, and drain the aux pump to get that seperate system also?
Tehe thanks.
Section 7 of the service manual lists the standard draining and refilling procedures and specs for the anitfreeze.
The manual does mention NOT to use Propylene-Glycol types of additives. They don't provide the required corrosion protection.
This why you should never use other additives like water wetter, etc..
