So far we have one Code 3 and 178mm.
Here is my next question: Which provides less risk to causing mechanical damage to the car?
Originally Posted by BlUEMDsrt6
After this fall there will enough information to better answer your question. Right now the 178mm pulley has put down the best numbers at the track, but this is because until recently it was the only pulley available. This fall alot of the guys with Code3 and other sized pulleys will be hitting the track with cooler weather. We should have hard evidence by then whether the code3 is just as good or better than a 178 and whether the 181 and 185 are any better than the 178. For now the 178 is king.
