Old Aug 15, 2008 | 12:30 AM
Mimi05SRT6's Avatar
Mimi05SRT6
Default Re: 185 pulley+ water/meth injection=??
Who says meth doesn't make more power? Methanol increases the octane well over 100. Take your car to a track on a 100 degree day and compare it to a 40 degree day and see where more power is gained. Same effect with methanol lowering the temps and increasing the engine power. I see peeps at the track lower their et's by nearly a half second just by adding methanol. Now if that's not adding more hp, then there is something wrong. By not having the timing pulled, you are making more power. When the timiing is pulled, you make less power. So I still don't get it when peeps say meth doesn't make more power. ??? Probably the best answer would be.... Meth prevents you from losing power. So, I guess they're right! LOL!
