Old Aug 18, 2008 | 04:31 AM
maxcichon's Avatar
maxcichon
Default Re: Ordering new rims, need advice asap
Originally Posted by bhays
I am ordering a set of ADR Decadence rims for my roadster.
They are 18x8.5 and 19x9.5. The seller (Elites-Wholesale.com) says I won't need spacers, but that doesn't sound right with what I've read here on the forum. Will I need 20mm spacers in the rear to make the front and back line up with the wheel well the same?
Thanks for any advice.
The ADR wheels, made by Golden Apple Corp. have a 66.56 mm bore for the 5X112 model. You will not need spacers for the hub fit, but, if the offset matches are not close enough you will.
Please use this tool:
http://www.rims-n-tires.com/rt_specs.jsp
and check the clearances before you need to.
