IMPORTANT :!: :!:
The oem wheel requires a lug bolt with a BALL taper. The oem wheel hub is also about 1/2" thicker than many aftermarket wheel.
Most after market wheels use a conical taper lug.
Be sure of which taper lugs you need before you order the longer bolts for use with the spacers.
--> If you are using aftermarket wheels+spacers, you may not need longer bolts, just different taper bolts of the same length.
-->If you are using OEM wheel+spacer, then you will need longer BALL taper bolts.
Nothing is ever easy these days... :?
