Old Aug 19, 2008 | 09:06 PM
ingsoc39's Avatar
ingsoc39
Default Oil change/pumping out oil
Hello, quick quesiton, has anyone used any of the mechanical pumps that you insert into the dipstick to change out the oil instead of going by way of drain plug? Griotts garage sells a nice one, however, they dont say exactly if it will work with the crossfire, and to work the hose which goes in the dipstick has to obviously be the proper diameter to fit in, AND they said it cant have a seperate dry sump (pressurized?) as in Porsches, or the pump won't work, I can order one and useit, and if it dosn't work return it, but would like to know if anyone has tried this or a similar device. thanks Scott
