I got mine at Brakeworld without a problem popeye. As a reminder, when you do the brake job, be sure to turn the rotors and use anti squeal grease or spray on the backs of the pads before installing. You may want to check out bedding the brakes, I don't want to see any squealing popeye threads.
Good luck with your brake job, I'm sure that you will enjoy a lot less brake dust to deal with.
Check out post #17
https://www.crossfireforum.org/forum...ad.php?t=22737
