Old Aug 21, 2008 | 07:02 PM
Kurts's Avatar
Kurts
Default Re: Bearings??? HELP NEEDED
Originally Posted by chuck65
A good way to detect bad bearings that's quite simple is to use a large screwdriver and put the blade on the alternator, while the engine is running, and put your ear to the handle. If the bearings are bad, the noise telegraphs up the handle and you can hear them rattling around. We used to use this method in the garage. Another way is to loosen the belt and spin the alternator, sometimes you can feel the grating of the bearings. Other causes of the noise could be from other devises driven by the serpentine belt such as the water pump or idler pulley or power steering pump.
Absolutely THE best way to listen for bearing noise: it's cheap, it's effective & it works just like a stethoscope. I used this to listen to printer bearings for 30 years. As long as you don't have to stick your face (& make dam_ sure your hair, shirt, tie, pants, if they're REAL baggie, are NOT going to pulled in!) next to a pulley you're good to go.
I was hoping that the member who started this thread would have responded back to us after he took the car in to be repaired to let us know the outcome so that we could all learn something. Too many times I've seen posts asking for help and not giving us any feedback once their problem is solved. Good Luck with your problem. AND LET US KNOW THE OUTCOME. We need to build our data base for future searches.
That WOULD be nice, wouldn't it !
