Thread: vent fan issue
Old Aug 22, 2008 | 06:55 AM
ThatGuy34's Avatar
ThatGuy34
Default Re: vent fan issue
Originally Posted by bigbengt67
It sounds like you are not in recirculate mode and the air moving along the car (higher pressure) is trying to get into the car (lower pressure) through the inlet under the cowl. This is pretty normal in most cars I have driven, I wouldn't think it is a huge problem. Try turning the recirculate mode on and see if you still get the problem, you shouldn't because the outside inlet will be blocked off.
that definately wasnt the issue. the fan was actually blowing the air. you could hear it running, and i could turn it on higher but it wouldnt turn off. i did also press the recirc button with no change. the problem was gone then next time i started the car and hasnt been back since.
