Old Aug 22, 2008 | 08:19 PM
nox1s's Avatar
nox1s
Default Re: Radio Locked in dash
Originally Posted by radicalrik
They had a complete Radio removal key kit. None of them worked. My understanding is once that spring has been release the only way to get it unrelease is by getting the deck out and resetting the side metal clips.
If the spring is released then it should slide out.. easy enough. Really, double check their tools.
http://www.crutchfield.com/App/Produ...l+tools&tp=990
Should look like the upper right tool on the right tool's side. (Does that make sense)?
To be honest, if you can't get the radio out this way, you're really out of luck.... the only other way to get the radio out is to take apart the lower dash, upper dash, glove box.. etc.. i've been there and it SUCKED.. and to be honest i don't even think you could do it that way because to remove the whole center console you do need to remove the radio.
