Originally Posted by NeverEnough
I see where you're coming from. That's a good way to look at it too. The only problem with this theory is that all these pulley were tested on different cars in different locations on different types of dynos that were are set up different. These number could easily change all over the place if they were all tested at the same time on the same dyno with the same conditions. .......
Negative - These are the hard core ratios determined by pulley sizes and mathematics. Not by different cars, dynos, locations, etc...
I should add that that's percentage of boost drive - not actual PSI - PSI gains are much more.. (around 15%)
