Old Aug 25, 2008 | 08:24 PM
amcordo's Avatar
amcordo
Default Re: Headlight Bulb vs. HID conversion
Originally Posted by coolb944
Hey all, I have another question. When you did the headlight conversion, did you just do the low-beams, or did you also do a conversion on the high beams? Does that require a whole second conversion kit?
I would suggest against this: usually when you need your brights you need them immediately, and as mentioned above HIDs have considerable warm up time.
Also, just like a video projector lamp an HID setup should be given time to cool down after being used before it's turned on again. So forget flashing your lights at someone...
