Originally Posted by MikeR
nocones, don't you have rubbing problems with the 285's on the front? Or do you have spacers to get them clear?
MikeR
with a 5mm spacer and a stock size wheel, the inside shoulder does rub on the ball joint bolt...cuts a very shallow groove in the shoulder...that's how I'm running right now
up that spacer to 1/4", which is a little over a mm wider and it won't rub at all...that's what soloIIracer on this forum is doing...that tiny bit of extra spacer is just enough to avoid rubbing
