Originally Posted by Eleventeen
With that much of a flow increase, I'm guessing we will be seeing less boost due to lower backpressure after the supercharger, but more power due to higher volume. This is a good thing since I already hit MAP limit. This might require a retune for best results (doesn't everything) due to the fact that fuel delivery is largely based on manifold pressure, and more air at a lower pressure might be deceiving to the ECU.
This mod sounds like it will make for some big power gains!
Hey eleventeen, where do you live?
