Old Aug 29, 2008 | 06:25 PM
maxcichon's Avatar
maxcichon
Exclamation Underhood filters and temp measurements
I thought this may have been lost in the old thread (https://www.crossfireforum.org/forum...ad.php?t=26728)
How Max spent his Friday:
I finally got around to making some measurements. They are with the splash shield in place. The experiment conditions were:
29 Aug 2008
Ambient temp 92 deg F.
Relative humidity 61%
Cruising speed 75 MPH
Intakes used
(A) 2 K&N RC-4650 on 3" Aluminum tubes 30 deg bend. (clean)
(B) 2 K&N 33-2290 in stock configuration. (clean)
(C) Same as (B) but with 1/4" foil faced self-adhesive
foam insulation on bottom of stock air box and filter boxes.
IAT = Inlet Air Temp (Nitrod/OBD info)
OT = Outside air temp (Crossfire dash display)
ET = Engine Temp/Coolant (Nitrod/OBD info)
UHT = Underhood Temp (Fluke/Ktype thermocouple.Placed midway between radiator and front of engine)
I ran up and down the I85 for 15 miles before each test to normalize. The temps displayed were stable +- 3 degrees for 10 miles.
This cost me a day and 1/3 tank of gas. I hope you folks appreciate it!
I will try to post this in columns. (I guess cut-n-paste don't work?)
. (A) (B) (C)
OT 92 92 92
IAT 134 108 106
UHT 134 137 144
ET 191 192 192
A couple of observations.
The faster you go, the lower the IAT's (duh).
The slower you go the higher the IAT's (duh).
After (B) and (C), I let the car idle for 10 minutes just to see how hot stuff gets.
(B) (C)
OT 92 94
IAT 140 131
UHT 189 188
ET 200 201
My uninformed conclusions.
Having the intakes/filters under the hood is a really bad idea. No matter how cool it looks.
If you want cool air to "launch" with, you had better keep the revs up to ~3000 for 15 seconds to cool off the intake/airbox. I saw this effect.
My cheap-*** insulation job seems to have some benefit.
If there is any interest, I'll take the bleedin' thing off again and snap a couple of shots.
I have no idea how the material I chose will hold up over time. We'll see.
I know you all think I'm a PITA, but at least I'm not a worthless PITA!
Comments?
