Old Aug 29, 2008 | 09:55 PM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: Tale of Three Dyno's
Below is dyno pull #20 (green) and #22 (red) (same day) after all the tuning was complete. Followed by the chart showing the AFR readings from the same runs. SI had a probe that sniffed pretty deep up the exhaust with the wide band mounted on the end outside the exhaust – this made for some pretty accurate and stable AFR readings (this will come into play later) Notice how the torque is nice and high above the HP line at the beginning of the run?…..
Here is the screen shot the converts the 308.1 peak HP Dyno Dynamic results into DynoJet numbers - 362.47 HP – can this be right?
