Old Aug 31, 2008 | 06:57 AM
rcompart's Avatar
rcompart
Default Re: JRindustries Ipod/Iphone docking station
Originally Posted by ppro
That's pretty nice.
One suggestion - you might want to offer relocation of the air bag warning light. Though it mainly serves to indicate when the air bag on the passenger side is turned off, it also acts as a warning light to indicate if there is a problem with the air bag system. Burying the light so that it can no longer be seen is a bit risky. As you probably know, the center portion of the socket is removable from the panel so can be put into some other location along with the lamp/lead.
That light has nothing to do with the actual operation of the SRS. It is only an indicator that is illuminated at start-up to acknowledge that the light is functional and then lights up when you turn off the passenger side airbag. The actual light for the SRS diagnostics and warning is on the cluster in the left set of warning lights. That's the one you want to make sure works.
