Old Aug 31, 2008 | 11:02 AM
cruzinquick's Avatar
cruzinquick
Default Re: Ordering a new pump: Johnson or Lightning-which is more reliable
The lightning requires to swap tops and either get a ford plug or use spades to tap the wires. Stock bracket is used with no modifying. The johnson has different size inlet/outlet so a different hose or clamps are needed along with modifying the stock bracket that holds the pump. Wires connections pretty much the same as lightning pump.
