Old Aug 31, 2008 | 11:12 AM
mrphotoman's Avatar
mrphotoman
Default Killer Chiller - intercooling option
There is another comany that makes these as well and is also a little cheaper. There is also an option to cool your intake temps as well. If you search the SVT, Cobra and Lightning forums they love these and posted up dyno's and videos showing the results.
http://killerchiller.com/
For air to air intercooling
any make or model
System will drop air charge
temperature approx 30 degrees
lower than standard passive systems
All electric. Alternator upgrade required.
System comes with "Chiller" assy, all electrical harnesses, LED lit power switch, brackets, hardware, basic digital gauge (optional upgrade available), and installation manual.
Dimensions:
33" length 6"Height 4"width 3"inlet - outlet Power requirement: 12-16 volts @ 40amps
From their FAQ page:
Using the AC, doesn’t it drag the motor down?
AC technology has come a long way, and is much more efficient. Most AC systems draw no more than 7-8 HP when in operation. When you’re talking about 400+ HP vehicles, you will be hard pressed to notice this deficit. When you go into boost, the low side pressure will drop, and cut the AC compressor off anyway, so there will be no parasitic loss under full throttle.
What are the benefits of running a KC system on my vehicle?
The KC system will lower your IC temps a minimum of 50-55 degrees F, this will substantially lower your air charge temps, prevent power fade, and timing retard, not to mention help protect your supercharged engine from detonation!
Does this only work for the street?
Absolutely not! We have people who are using the KC on their vehicles for open track as well as the quarter mile strip, with great success I might add!
How hard is the KC system to install?
The KC comes with everything you need for a complete installation, however you will need to have your refrigerant recovered by an AC shop, afterwards you can do the install yourself if you are comfortable with using regular hand tools, then you will need to go back and have them add the refrigerant back to your AC system. If you are good with tools, figure 3-4 hours, otherwise plan an 8 hour day.
Will this decrease the life expectancy of my AC system?
No. The KC is ran in series right after the orifice tube, which means it’s not on a separate loop ( or in parallel), the refrigerant is still run through the stock accumulator/receiver drier, before cycling back into the compressor. If you have a vehicle that uses an expansion valve, than your kit will have an extra drier, as well as an accumulator.
We have been running this system for many years now with zero problems.
Will this system effect my in cab temperatures?
You will see about an average of 5-7 degrees increase in the in cab temps under optimum conditions, but you can also adjust the refrigerant level to have more cooling in the cab, and less in the KC, by the same token you can adjust your refrigerant levels to see more cooling in the KC , and less in the cab.
How does the Electric KC systems work?
The all electric KC system employs high powered Thermoelectric modules, which moves heat from one side of the module (the cold side) to the other side of the module which is connected to a heat sink (the hot side). This basically pumps the heat out of the intercooler into the heat sink, which in turn dissipates the heat to atmosphere.
These systems are great for low boost applications, as well as fuel cooling.
How much power will the Electric KC systems draw?
These systems typically draw 40 to 60 amps depending on which system you choose, and require an alternator upgrade. Alternator upgrade not required for AC driven KC systems.
