Old Sep 1, 2008 | 12:30 PM
kjnc's Avatar
kjnc
Default Re: Bought K&N air filters...now need find instructions...
Originally Posted by 70GT6
*** IF LIKE SRT***
Pull up on each side and the front, one place at a time. There are clips in rubber mounts that will release. Lift off cover.
You then will have to use a torx driver to remove the screws from each air filter cover. (6 or 8 each) I did not have to disconnect any hoses.
Just lift the covers enough to remove/replace the filters. (DO NOT forget to install the foam spacers included with the K&Ns. They stick to the underside of the filter covers, in the "groove")
I didn't get any foam spacer with my K&N replacement air filters?!
kjnc
