Old Sep 2, 2008 | 09:48 AM
Eleventeen's Avatar
Eleventeen
Default Re: supercharger clutch noise
Originally Posted by waldig
The S/C clutch engauges when you go above about 1800 rpm and it stays on until you stop moving or coast for over about 30 seconds.
There are a few that dont believe this, to check this out get a bud in the driver seat to put on the foot brake NOT PARKING and in gear, torque it up to about 1800 Rs and you will see the clutch turn on and go OFF when the reves are dropped. THe wheels are not moving, that kicks the S/C off.
THe stock clutch surface is not too big and it can slip if there is not enough material and tension to cause it to "lock Up"
The code 3 change was way easy to install and the bearing comes with it too.
Clutching at the truth, Woody
1800RPM? Now is that when applying only GENTLE pressure to the accelerator? Or can you just not get it to engage below 1800 at all? I ask because mine will engage immediately off of idle if I apply at least moderate throttle. Maybe Jerry does something to enable earlier engagement in his tunes, or maybe it's a difference in software between Mercedes and Chrysler.
