Re: 6 Spd M/t Service Bulletin Question
You just perfectly described what synchronizer rings do when they start to go bad.
Basically, all they do is make it easier to shift into a gear, when the gears are aligned they shift good, up until the point that the clutch is disengaged and the gears once again go out of alignment.
