mrphotoman,
Replacing the cup holder with the bin is a piece of cake and really does only take about 15-20 minutes to do. The part number for the Bin is 1BQ12XDVAA and it is $37.91 plus shipping from
Chrysler Parts Direct. The bin went up $12 from last year when I replaced mine.
Here is the procedure:
- Remove trim plates around shift lever by pulling up and back.
- Remove the rubber cover from the emergency brake handle, use a little soap between the rubber and metal handle and it will slip right off.
- There are two screws at the front of the console and two nuts at the back (inside the storage compartment at the rear...pull carpet forward about two inches) that must be removed.
- Lift the console up from the front and slide forward.
- Disconnect any electrical connections and completely remove the console.
- Lay the console upside down (on a towel) and remove 4 torx screws holding the cup holder in place.
- Reverse the removal process to reinstall the console.
