Old Aug 14, 2004 | 03:50 PM
David Burns's Avatar
David Burns
Default Re: engine oil capacity... one more time? 6.1QT vs. 8.5QT
Originally Posted by former NXMX5
And finally, what do i do now? :?
Drain bit out until the stick and the electronic system are reading "okay" level.
A quick search for SLK320 engine info found:
http://www.slk32.com/pages/engines(usa)/engines2.html
but it doesn't list any capacities.
This page http://www.slk32.com/pages/oilchange/oilchange.html says:
"The 3.2 liter engine uses 8.5 US quarts. It is recommended that only 8 quarts be added initially. Run the engine and check the level. The oil canister/filter can hold about a quart of oil so the level will drop after the oil is circulated for the first time. Add oil as needed."
