Old Sep 11, 2008 | 01:41 PM
Coyote's Avatar
Coyote
Default Re: BRAGGING RIGHTS (lame, i know)
Originally Posted by tighed1
Hey Waldig
Have read some of your other threads reference H/E cooling when I first hit the "no supercharger" overtemp problem once I had installed the Code 3 pulley.
Looks like you currently have a transmission cooler in-line with the stock H/E.
I have the exact trans cooler new in a box from a previous project. Will I benefit from installing it as you appear to have done?
I took the Code 3 pulley off this morning because I am sick of having no power after driving a dozen miles or so.
Is that a Summit generic aluminum radiator and are you going to make a H/E out of it???
Thanks for your time and all of your efforts directed towards the Crossfire family!
Tighed1, I've had the code 3 pulley installed for about 5 months now, and I've had no problem
at all with over temps. I did have such problems a couple years ago, but that was a result of
a failing IC water pump. Before you ditch the code 3 pulley, try changing out the IC water pump.
Coyote
