Old Sep 12, 2008 | 09:27 AM
Eleventeen's Avatar
Eleventeen
Default Re: Okay whats the HP now
Originally Posted by BLKFIN
I have similar mods and did 320rwhp/323tq on a dynojet during a 90 degree day. According to the calculator BrianBrave posted that is 376rwhp/380tq at the crank. You can not just add the HP numbers that mods on their own created. Unfortunately you will never see the 26hp for the intake added to 40hp for the pulley and 20hp for the tune. You get a “blended” amount of these three mods working together that is much lower.
Actually, the total gain is often greater than the individual numbers combined (assuming you are using HONEST numbers). For instance: If you add a high flow exhasut to a car that is otherwise stock, you will not pick up as much power from the addition of the exhaust system as you would installing it on a car that already had a high flow intake and pullies to induct more air. The more air you're taking in, the more important it is to get exhaust out. This is why it is important to know if an aftermarket part was tested on a stock vehicle or an already modified vehicle, as performance parts will many times yield higher gains on a car that has complemetary mods.
