Originally Posted by ZORRO
I am painting the dash, or more likely having it painted. Are these two tabs the small black rectangular plastic ones you see when you look inside the lighter receptacle? What is a right angle hook tool? Like a dental tool?
Thanks
Zorro
The black tabs are on the outside part of the lighter socket that hold it to the plastic fascia piece. A right angle hook tool is pretty much a small much that has the last half inch bent at a right angle to the rest of the shaft. You could use a dental pick tool too and those are sometimes for sale at automotive parts stores. YMMV
Good luck and hope it helps.
