Originally Posted by Uncle_Al
Hey Drunkiq - I did the egg whites and nutmeg thing but upon icing it I found the resulting absquatulation to be untenable. Any suggestions?
Uncle Al,
We are all subsisting in the infinite macrocosm awaiting our inevitable state of quietus. With that said keep in mind that your result may be skewed depending on your intentions with the concoction after it was fabricated. Normally once a being has been exposed to a artifact of this magnitude, the end result will usually be its demise. If you or a pet are one of the small percentages of a less than one percent of the population that have ingested the mixture, it is feasible that a multitude of tribulations of the gastric intestinal temperament have arisen. In view of the fact that only such a small fall out is expected the FDA has tentatively approved this method as it benefits the residual ninety-nine plus percent of the population to disregard what the original post was about without any disorderly physical functions. The appropriate and projected procedure is for the mixture to be placed into a disposal device after it has been examined. If this was the course of action that you have foretoken then the disclaimer worked as intended.
Regards,
-marc
